Knowledge Base Article
Why is the I2C Avalon® Memory Mapped FPGA Host Bridge not writing to On-Chip RAM correctly when using Quartus® Prime Pro Edition Software?
Description
When using the Avalon® Memory Mapped Host Bridge Core for writing into On-Chip RAM, the data might get lost or incorrectly written into memory.
This behavior can be observed when writing a stream of 4 bytes to memory in certain memory offsets, in some cases, the fourth byte will not be written or misplaced into the i2c_avalon_master_address signal.
This problem occurs because of the following reasons:
This problem was found in the Quartus® Prime Pro Edition Software version 19.1 for Linux*.
Resolution
To overcome the problem, download the Latest Device Firmware for the Quartus® Prime Pro Edition Software version 22.2 from the following knowledge article:
This problem is fixed in the Quartus® Prime Pro Edition Software v22.3 and Quartus® Prime Standard Edition Software v22.1 onwards.
Updated 6 hours ago
Version 5.0
