Knowledge Base Article
Why is the GTS PMA/FEC Direct PHY IP version 5.0.0 in the Quartus® Prime Pro Edition Software project generated with QPDS 24.2 not auto upgrading the IP to version 6.0.0 in version 24.3?
Description
The GTS PMA/FEC Direct PHY IP version 5.0.0 generated with version 24.2 is not auto-upgrading to IP version 6.0.0 in 24.3 due to the changes in IP parameter values.
Resolution
To upgrade the GTS PMA/FEC Direct PHY P version 5.0.0 generated with version 24.2 to version 6.0.0 of the IP in Quartus® Prime Pro Edition Software version 24.3, you need to manually upgrade the IP, enable custom PCS, select a valid value for the custom PCS interface, and then regenerate the IP.
The table below shows the changes in parameter value for IP version 6.0.0.
Select Custom PCS interface
S.No
Parameter value in IP version 5.0.0
Equivalent Parameter Value in IP Version 6.0.0
1
IEEE
IEEE MII Interface
2
IEEE_FLEXE_66
IEEE_FLEXE_66
3
PCS66
PCS66
For more details on the custom PCS interface, please refer to the GTS Transceiver PHY User Guide.
This problem is fixed in the 24.3.1 release of the Quartus® Prime Pro Edition Software.
Updated 1 year ago
Version 2.0
