Knowledge Base Article
Why is the GTS PMA/FEC Direct PHY IP not getting configured with the provided Presets and showing errors?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3.1, using either of the two presets shown below with the GTS PMA/FEC Direct PHY IP will generate an error message while being used for configuration.
S.No.PMA/FEC Direct Presets             Description
1FECDirect_10G_1_Lane_System_PLL_FirecodeFECOne FEC Direct GTS lane, operating at 10.3125 Gbps with system PLL clocking mode (Firecode FEC enabled)
2PMADirect_6G_2_System_PLL_Custom_CadenceTwo PMA Direct GTS lanes, operating at 3.4 Gbps per lane, with system PLL clocking mode (Custom cadence enabled)
The issue is limited to only these two preset configurations.
Resolution
This problem is planned to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 27 days ago
Version 2.0
