Knowledge Base Article
Why is the FPGA fabric unable to access the QSPI device through the SDM mailbox when ATF is used as the HPS bootloader in release 26.1 and earlier?
Description
Due to the current implementation of Arm Trusted Firmware (ATF), BL31 retains ownership of the QSPI device after HPS boot in flows where ATF is used as the HPS bootloader (for example, ATF-to-Linux direct boot flow or bare‑metal boot flow). As a result, the FPGA fabric is unable to access the QSPI device through the SDM mailbox. This issue is observed in ATF releases 26.1 and earlier and affects Agilex® 7 FPGA, Agilex® 5 FPGA, and Agilex® 3 FPGA devices.
Resolution
There is no workaround for this issue. For Agilex® 5 FPGA and Agilex® 3 FPGA devices, this problem will be addressed in a future release by introducing an ATF build‑time switch that allows control over whether QSPI ownership is retained by or released from the HPS.
Updated 6 months ago
