Knowledge Base Article
Why is the E-Tile JESD204C Intel® FPGA IP bonded design example unreliable during link-up on hardware?
Description
Due to an E-Tile transceiver PMA limitation, the E-Tile JESD204C Intel® FPGA IP bonded design example fails intermittently during link-up. Failure will cause either sync header lock (SH_LOCK) or extended multiblock lock (EMB_LOCK) at the receiver side to not be asserted.
This problem is caused by an E-Tile PMA limitation where TX deskew misalignment occurs when channel bonding and double width transfer mode settings of the E-Tile Transceiver Native PHY IP in the E-Tile JESD204C Intel® FPGA IP are enabled.
This problem can be observed using the E-Tile Transceiver Native PHY IP PMA Avalon® Memory-Mapped Interface at address 0x9h:
  • cfg_tx_deskew_sts[2] (0x9 bit[4]) shows '0’
  • cfg_tx_deskew_sts[1:0] (0x9 bit[3:2]) shows NOT '11’
Resolution
Due to the E-Tile transceiver PMA limitation, bonded mode option can no longer be supported.
Starting in version 23.3 of the Intel® Quartus® Prime Pro Edition Software, only non-bonded modes will be supported.
Updated 1 month ago
Version 2.0
