Knowledge Base Article
Why is the DisplayPort Intel® FPGA IP Design Example missing audio data packets and secondary data packets in the Intel® Quartus® Prime Pro Edition Software version 23.1?
Description
Due to a problem with the DisplayPort Intel® FPGA IP, you may observe secondary data packet mismatch errors when using the IP in Displayport version 1.4 video testing with 4 lanes.
Hence, there are no secondary data packets and no audio data packets.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 23.1.
Download and install Patch 0.20 from the following links:
This problem has been fixed starting in version 23.2 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 4.0
