Knowledge Base Article
Why is the “Using Quartus Generated Example Design” check box in the Ethernet Toolkit disabled even using the E-Tile 100G Ethernet Hard IP example design generated by the Quartus® Prime Pro Edition Software version 21.2 ?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 21.2, you may see the “Using Quartus Generated Example Design” check box in the Ethernet Toolkit is disabled even when using the E-Tile 100G Ethernet Hard IP generated example design.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 22.3.
Updated 3 months ago
