Knowledge Base Article
Why is a flickering video output observed for the Agilex® DisplayPort FPGA IP when programming the SST Parallel Loopback Design Example on hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3.1, a flickering image output will be observed from the DisplayPort Source. This issue affects the Linux* and Windows* versions of the Quartus® Prime Pro Edition software.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition software version 24.3.1. Download and install Patch 1.02fw from the link below.
Download patch 1.02fw for Windows
Download patch 1.02fw for Linux
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.
Updated 4 months ago
Version 7.0
