Knowledge Base Article
Why doesn't the Intel® Stratix®10 MX HBM2 controller assert the AXI RVALID signal until the AXI RREADY is asserted from the user interface?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 19.4 and earlier, the Intel Stratix® 10 MX HBM2 IP doesn't assert the axi_<x>_<y>_rvalid signal until the axi_<x>_<y>_rready signal is asserted from the user interface.
Note that <x> and <y> refer to channel and pseudo-channel number respectively.
Resolution
For the Intel® Quartus® Prime Pro Edition Software version 19.3 and earlier, you can work around this problem by opening the altera_axi_ufi_soft_logic.sv file and changing the following:
(starting from line 423:)
assign ufi_rready = PHY_THROTTLE_RDATA_BRESP ?
//  (rready & rdata_fifo_almost_empty) : rready;   // before
     (rdata_fifo_almost_empty) : rready;                    //after
generate  if(PHY_THROTTLE_RDATA_BRESP) begin
// assign rvalid             = (rready & ~rdata_fifo_empty);  //before
    assign rvalid             = (~rdata_fifo_empty);                  //after
This problem is scheduled to be fixed in a future release of the Intel Quartus Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
