Knowledge Base Article
Why does the Triple-Speed Ethernet FPGA IP report a Length Error (rx_err[1]) for undersized packets?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3, the Triple-Speed Ethernet FPGA IP will report a Length Error (rx_err[1]) whenever an undersized packet is received.
Resolution
To work around this problem, set the PAD_EN bit in the command_config[5] register to 1.
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 25.1
Updated 1 year ago
Version 3.0No CommentsBe the first to comment
