Knowledge Base Article
Why does the transmitter jitter increase when resetting adjacent transceiver channels?
Description
You may observe increased jitter on an active transmitter channel with CMU PLL while resetting adjacent transceiver channels. This problem is caused when the CMU PLL high speed serial clock is enabled or disabled simultaneously on the adjacent channels, which causes a sudden local increase in the current consumption and jitter on the active transmitter channel.
Resolution
To work around this problem, use ATX PLL or fPLL instead of CMU PLL.
This problem will not be fixed in a future release of the Intel® Quartus® Prime Edition versions.
Updated 11 months ago
Version 3.0
