Knowledge Base Article
Why does the Stratix® 10 Interlaken (2nd Generation) IP Example Design fail in non-continuous mode (Transfer Mode selection set to packet)?
Description
Due to a problem with the Stratix® 10 Interlaken (2nd Generation) IP Example Design Packet Transfer mode pattern generator may generate incorrect payload data if the signal itx_ready deasserts during the last packet transfer (i.e. packet 100).
Resolution
To work around this problem using Intel® Quartus® Prime v19.1 modify the files "ilk_pkt_gen.sv" and "ilk_pkt_gen_mseg.sv" found in the folder /<your example design>/example_design_s10/rtl/as shown below.
ilk_pkt_gen.sv
Change From:
always @(posedge clk) begin
if (tx_usr_srst_r[0]) begin
stop_pkt <= 1'b0;
end else if (pkt_cnt == 7'd100 && !continuous_pkt ) begin
// end else if (pkt_cnt[6] & pkt_cnt[5] & pkt_cnt[2]) begin
stop_pkt <= 1'b1;
end
end
Change To:
stop_pkt <= 1'b0;
end else if (pkt_cnt == 7'd100 && !continuous_pkt && tx_eopbits_nxt[3]) begin
stop_pkt <= 1'b1;
end
end
ilk_pkt_gen_mseg.sv
Change From:
stop_pkt <= 1'b0;
end else if (pkt_cnt_sop == 7'd100 && !continuous_pkt ) begin
// end else if (pt_cnt[6] & pkt_cnt[5] & pkt_cnt[2]) begin
stop_pkt <= 1'b1;
end
end
Change To:
stop_pkt <= 1'b0;
end else if (pkt_cnt_sop == 7'd100 && !continuous_pkt && (state == ST_C3) && tx_ready) begin
stop_pkt <= 1'b1;
end
end
The problem has been fixed starting with Quartus® Prime Pro Edition software version 19.2.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
