Knowledge Base Article
Why does the Stratix® 10 EMIF Toolkit report DQS Enable Calibration failure?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 19.3 and earlier, the Intel Stratix® EMIF Toolkit calibration report may show a DQS Enable Calibration failure even though both the DQ/DQS read and write margins show passing valid window values.
This DQS Enable Calibration failure report can be ignored if the DQ/DQS read and write margins show passing valid window values.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 19.3 and earlier, you can also verify that the local_cal_success signal is asserted using the Signal Tap Logic Analyzer tool.
This problem is fixed in the Quartus Prime Pro Edition Software version 19.4 and later.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
