Knowledge Base Article
Why does the SDI II IP design example generation fail when using the Quartus® Prime Pro Edition Software for Windows?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 21.3 and version 21.4 for Windows*, and Quartus® Prime Standard Edition Software version 22.1, the SDI II IP design example generation will fail with the following error message:
"Error: Failed to generate example design example_design to:: <design directory>\sdi_ii_0_example_design"
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 21.3.
Download and install Patch 0.28 from the appropriate link below.
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 21.4.
Download and install Patch 0.05 from the appropriate link below.
A patch is available to fix this problem for the Quartus® Prime Standard Edition Software version 22.1.
Download and install Patch 0.01std from the appropriate link below.
This problem is scheduled to be fixed in a future version of the Quartus® Prime Standard Edition Software.
This problem has been fixed starting in version 22.1 of the Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0
