Knowledge Base Article
Why does the SDI II IP Design Example fail to generate pathological patterns?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3 and earlier, you may observe the high bit-error rates on recovered data when receiving 12G SDI pathological patterns on
- Agilex® 7 - F-Tile PMA/FEC Direct PHY FPGA IP
- Agilex® 5 - GTS PMA/FEC Direct PHY IP
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
You should be able to select the RX adaptation mode from the native adaptation mode in the
With this implementation, you can reliably drive the 12G SDI link with up to 15dB of total insertion loss, as validated and quantified from the output of the re-timer to the Agilex® 7/5 FPGA receiver input. You should ensure the selected re-timer is capable of compensating up to 8dB of channel loss with pre/de-emphasis.
Updated 4 months ago
Version 8.0No CommentsBe the first to comment
