Knowledge Base Article
Why does the Quartus® Prime Pro fitter fail when compiling the Agilex® 5 GTS HDMI IP Clocked Video design example with the HDMI PHY?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1, the fitter may fail during placement when compiling the Agilex® 5 GTS HDMI IP design example configured with the Clocked Video interface with the HDMI PHY configuration. The failure occurs while routing a core global signal for the HDMI receive path and reports that no valid lab location can be found near chip coordinates (157, 74). The fitter then exits unsuccessfully.
Resolution
This problem will be fixed in a future release of the Quartus Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
