Knowledge Base Article
Why does the Nios® V processor force Configuration Scheme with Memory Initialization for MAX® 10 FPGA?
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 23.1 and 24.1, you may see an error below when using Dual Compressed Image as the Internal Configuration mode for Nios® V Processor Design on MAX® 10 FPGA,
Error (16031): The current Internal Configuration mode does not support memory initialization or ROM. Select Internal Configuration mode with ERAM.
Note: Assuming that memory initialization is disabled in every on-chip memory.
Resolution
To work around this problem,
Download and install the patches below for the Quartus® Prime Standard Edition Software version 24.1.
- Quartus® Prime Stardand Edition Software v24.1 Patch 0.01std for Windows (.exe)
- Quartus® Prime Stardand Edition Software v24.1 Patch 0.01std for Linux (.run)
- Readme for Quartus® Prime Stardand Edition Software v24.1 Patch 0.01std (.txt)
Download and install the patches below for the Quartus® Prime Standard Edition Software version 23.1.
- Quartus® Prime Stardand Edition Software v23.1 Patch 0.03std for Windows (.exe)
- Quartus® Prime Stardand Edition Software v23.1 Patch 0.03std for Linux (.run)
- Readme for Quartus® Prime Stardand Edition Software v23.1 Patch 0.03std (.txt)
The problem has been fixed starting with Quartus® Prime Standard Edition software version 25.1,
