Knowledge Base Article
Why does the Low Latency 100G Ethernet Stratix® 10 FPGA IP show 'H-Tile' as 'Target transceiver tile' when targeting a 'L-Tile' only device?
Description
When working with a 'L-Tile' only device, the 'Target transceiver tile' drop down menu is disabled and shows the 'H-Tile' default value. 'H-Tile' is coded in the component description file as its default.
Resolution
The designer can safely ignore the 'H-Tile' as 'Target transceiver tile' when targetting L-Tile devices, the IP will generate HDL targeting the correct device tile. This problem will be fixed in a future release of the Quartus® Prime Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
