Knowledge Base Article
Why does the Intel® Stratix® 10 E-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example generation fail?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition version 21.2 Software, you may see the Triple-Speed Ethernet Intel® FPGA IP 10/100/1000Mb Ethernet MAC (Fifoless) with 1000BASE-X/SGMII 2XTBI PCS with E-Tile GXB Transceiver Design Example generation fail.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 21.2.
Download and install Patch 0.15 from the appropriate link below.
Download the patch Intel® Quartus® Prime Pro Edition version 21.2 Patch 0.15 for Windows (.exe)
Download the patch Intel® Quartus® Prime Pro Edition version 21.2 Patch 0.15 for Linux (.run)
Download the Readme for Intel® Quartus® Prime Pro Edition version 21.2 Patch 0.15 (.txt)
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 3 months ago
Version 3.0
