Knowledge Base Article
Why does the GTS AXI Streaming IP for PCI Express* on Agilex® 5 FPGA D-Series remain in reset or fail to initialize after system boot?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.3, the GTS AXI Streaming IP for PCI Express* on Agilex® 5 FPGA D-Series devices may not initialize successfully. Devices programmed with a .sof file or an image generated by version 26.3 may exhibit the following symptoms:
- The PCIe IP remains in reset.
- The PCIe endpoint fails to enumerate.
These symptoms may occur even though device configuration and overall system boot-up have completed successfully.
Impacted Agilex 5 OPN
- A5Dx130xxxxxxxx
- A5Dx160xxxxxxxx
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 1 hour ago
