Knowledge Base Article
Why does the frequency generated by the PHY Lite for Parallel Interfaces Intel® Arria® 10 FPGA IP is different from the user input frequency?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.1 and the Intel® Quartus® Prime Standard Edition software version 18.1 update 1, you may see that the Interface clock frequency, PLL reference clock frequency and VCO clock frequency of the PHY Lite for Parallel Interfaces Intel® Arria® 10 FPGA IP generated is different from the user input frequency. When you perform an RTL simulation, you will see that the frequency used is the user input frequency instead of the frequency in the compilation report.
For example,
Resolution
To avoid rounding error in the RTL simulation, frequencies are round up to the nearest even number so that every clock edge is aligned during simulation. However, in the real hardware, the frequency will be the frequency in Compilation Report.
Updated 2 months ago
Version 2.0
