Knowledge Base Article
Why does the Ethernet 10G MAC Intel® FPGA IP's XGMII interface output last few bytes of data with unknown state in simulation?
Description
You may encounter above problem if the csr_reset signal of Ethernet 10G MAC Intel® FPGA IP did not toggle once after the start of simulation.
Resolution
To work around this problem, the csr_reset signal must be toggled once at the beginning of simulation.
Updated 2 months ago
Version 2.0
