Knowledge Base Article
Why does the EMIF Traffic Generator 2.0 become unresponsive when the burst length reaches or passes the end of the memory address space?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 20.4 and earlier, you may see that the EMIF Traffic Generator 2.0 (TG2) does not assert the pass, fail, or timeout signals when the TG2 is set to sequential mode and the written address is within 127 address spaces to the end of the memory.
For example, if the address 0xfff0 is written to with a burst length of 0x20, the TG2 will become unresponsive because this is an invalid command.
Note: This problem does not occur when the TG2 is set to random mode or random-sequential mode because the address is generated to account for the size of the burst length.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 21.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
