Knowledge Base Article
Why does the EMIF or HPS EMIF calibration fail when sharing the IO Bank with the MIPI D-PHY IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, you may observe Fabric EMIF calibration failure or HPS EMIF calibration failure when the Fabric EMIF or HPS EMIF is sharing the same IO Bank with MIPI D-PHY IP.
This problem does not impact the DDR4 and DDR5 HPS EMIF implementation that is sharing only the RZQ pin with the MIPI D-PHY IP.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1,
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
