Knowledge Base Article
Why does the DMA write performance of the Intel® Stratix® 10 PCIe* Avalon®-MM Hard IP  implemented in Platform Designer degrade with Intel® Quartus® Prime Pro version 19.1?
Description
When using Intel® Quartus® Prime Pro version 19.1, the Intel® Stratix® 10 PCIe* Avalon®-MM Hard IP with DMA has a performance issue for DMA writes when using Platfrom Designer Avalon®-MM interconnect, which results in decreased throughput.
Resolution
Standalone implementations not using Platform Designer are not affected by this problem.
If using Intel® Quartus® Prime Pro version 19.1, then download and install the patch 0.08 below to fix the DMA write efficiency problem.
Download the Intel® Quartus® Prime Pro version 19.1 patch 0.08 for Windows (.exe)
Download the Intel® Quartus® Prime Pro version 19.1 patch 0.08 for Linux (.run)
Download the Readme for the Intel® Quartus® Prime Pro version 19.1 patch 0.08 (.txt)
This problem is fixed starting with the Intel® Quartus® Prime Pro software version 19.2.
Updated 8 months ago
Version 4.0
