Knowledge Base Article
Why does the avst_source_u_data data interface overflow when using Block floating-point (BFP) compression with the O-RAN FPGA IP?
Description
Due to a problem in the O-RAN FPGA IP, raw IQ Samples (iSample and qSample) data exponent only supports up to power of 7 in Block floating-point (BFP) compression.
If the exponent is larger, the avst_source_u_data interface will overflow.
Resolution
To work around this problem, users should ensure that they scale the raw IQ Sample data to keep the exponent within 7.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.
Updated 5 months ago
Version 6.0No CommentsBe the first to comment
