Knowledge Base Article
Why does the 25G Ethernet Intel® FPGA IP transmit incorrect traffic when either TX start of packet (SOP) or end of packet (EOP) are asserted on the same cycle the valid signal was de-asserted?
Description
Due to a problem with the Intel® Quartus® Prime Pro Edition Software version 19.1 software, the 25G Ethernet Intel® FPGA IP with ready latency set to 3 will transmit incorrect traffic when either the TX start of packet (SOP) or end of packet (EOP) signals are asserted on the same cycle as the valid signal was de-asserted.
Resolution
To work around this problem, only assert TX start of packet (SOP) or end of packet (EOP) when the valid signal is asserted.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 19.3.
Updated 3 months ago
Version 3.0
