Knowledge Base Article
Why does the 25G Ethernet Intel® FPGA IP fail to achieve 100% throughput?
Description
Due to a problem in the 25G Ethernet Intel® FPGA IP core, for Intel® Quartus® Prime Pro Edition Software version 20.2 and earlier, you may see the IP fail to achieve 100% throughput.
This is because the IP does not compensate for the data rate loss due to RSFEC Alignment Marker Insertion on the TX data path. The 25G Ethernet Intel® FPGA IP Core is not adhering to section 108.5.2.2 "rate compensation for codeword markers in the transmit direction" of the IEEE 802.3 spec. As a result, the IP is unable to achieve throughput higher than 99.995%.
Resolution
No workaround to this problem exists.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 20.3 for the Intel® Stratix® 10 device.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 20.4 for the Intel® Arria® 10 device.
Updated 11 months ago
Version 3.0
