Knowledge Base Article
Why does my VHDL variant of the eCPRI Intel® FPGA IP fail to simulate in Synopsys VCS MX®?
Description
Due to a problem in the Intel® Quartus® Prime software versions 20.1 and later, when using a VHDL variant of the eCPRI Intel® FPGA IP in Synopsys VCS MX*, the simulator’s compiler will flag errors stating that there are type mismatches for parameter “ADV_MAP”.
Resolution
To work around this problem in the Intel® Quartus® Prime version 20.1 and later, follow the steps below:
1) Locate the generated top-level wrapper file of your eCPRI Intel® FPGA IP here:
<variant_name>/sim
2) Change every “ON” or “OFF” string that is assigned to the parameter “ADV_MAP” to integer 1 or 0, respectively, as shown below:
From
ADV_MAP : string := "ON";
To
ADV_MAP : integer := 1;
From
ADV_MAP => "OFF",
To
ADV_MAP => 0,
This problem is fixed starting with the Intel® Quartus® Prime software version 20.3.
