Knowledge Base Article
Why does internal serial loopback test results fail when running the GTS JESD204B FPGA IP Design Example on Agilex™ 3 FPGA or Agilex™ 5 FPGA hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, you may encounter a failed test result when running the internal serial loopback test with the GTS JESD204B FPGA IP Design Example.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software versions 25.3, download and install patch below.
After installing the patch, do the following:
  1. In the GTS JESD204B IP GUI editor, IP > Main tab, enabled the following checkboxes:
    1. Enable PMA Avalon memory-mapped interface
    2. Enable control and status registers
  2.  Depending on the data rate, configure the IP ➤ Analog Parameters ➤ Analog Rx ➤RX Adaptation mode:
    1. Manual: if data rate <= 7Gbps
    2. Auto: if data rate > 7Gbps
  3. Regenerate the design example.
This problem will be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 3.0
