Knowledge Base Article
Why do write operations fail with an MT25QU01G flash device when using the FPGA Generic QUAD SPI Controller II Core?
Description
Due to a problem in the FPGA Generic QUAD SPI Controller II version 18.1, erase operations starting from sector 256 onwards will fail, causing all write operations to be unsuccessful when using an MT25QU01G flash device.
Erase and write operations executed below sector 256 will be performed without problems.
This problem affects the FPGA Generic QUAD SPI Controller II included with the Quartus® Prime Standard Edition Software version 18.1
Resolution
To work around this issue, please download and install the patch file for your Operating system:
This problem is fixed starting with the Quartus® Prime Software version 19.1.
Updated 7 months ago
Version 4.0
