Knowledge Base Article
Why do I see the Errors in data transmission of the GTS PMA/FEC Direct PHY FPGA IP for PMA configuration rules set to CPRI with Fiber Channel RS(528,514) Forward Error Correction (FEC) enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, when using the GTS PMA/FEC Direct PHY FPGA IP with the configurations shown below, errors will be observed in data transmission,
PMA configuration rules --> CPRI
FEC mode --> Fiber Channel (FC) RS(528,514) Forward Error Correction (FEC)
Data Rate --> 10G
Resolution
This problem is fixed in 24.3.1 release of the Quartus® Prime Pro Edition Software.
Updated 1 year ago
Version 2.0
