Knowledge Base Article
Why do I see rx_ready not asserting, or incorrect TX data rates in Agilex® 7 F‑Tile or Agilex® 5/3 FPGA GTS device transceiver simulations using the Quartus® Prime Pro 25.3.1 or earlier software with Siemens QuestaSim® Altera Edition software?
Description
Due to a bug in the Quartus® Prime Pro 25.3.1 and earlier software for Agilex® 7 F‑Tile or Agilex ® 5/3 FPGA GTS devices, you may see the rx_ready signal not asserting, or incorrect TX data rates when simulating with the Siemens QuestaSim* Altera® Edition software.
Resolution
To work around this problem, you can update your design to the Quartus Prime Pro software version 26.1 and create a script that sets the following environment variables and then calls the Quartus Prime Pro software generated msim_setup.tcl file.
set QUARTUS_SIM_LIB_DIR <quartus_installation>/quartus/eda/sim_lib2
set DEVICES_SIM_LIB_DIR <quartus_installation>/devices/sim_lib2
set ENABLE_QE_LIBRARY_COMPILATION "true"
source msim_setup.tcl
This problem will be fixed in a future version of the Quartus Prime Pro software.
Updated 6 months ago
Version 3.0No CommentsBe the first to comment
