Knowledge Base Article
Why do I see permission denied error in Windows (64-bit) when using ModelSim*- Altera® FPGA to simulate Agilex® 7 CPRI PHY IP Example Design on the Quartus® Prime Pro Edition software version 21.4?
Description
The issue occurs when using ModelSim®–Altera FPGA to simulate the Agilex® 7 CPRI PHY IP Example Design on a Windows (64-bit) system. This problem does not occur when running the same simulation on a Linux system.
Resolution
To work around this problem:
  1. Create a new folder called temp under example testbench.
  2. Copy the MIF file into it.
  3. In the script ./example_testbench/sim_script/common/modelsim_files.tcl, revise the MIF path. lappend memory_files "[normalize_path "$QSYS_SIMDIR/../temp/cpriphy_ftile_hw__tiles__z1577a_x388_y0_n0.mif"]"
    Alternative:
    In the script ./example_testbench/sim_script/mentor/msim_setup.tcl, revise as follow.
    Line 188: file copy -force $file ./ ----> catch { file copy -force $file ./ }
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 22.2.
Updated 5 months ago
Version 2.0
