Knowledge Base Article
Why do I see compilation failure in the design using F-tile Ethernet Hard IP at 25GE-1 variant for non-MAC PCS direct mode with Firecode FEC enabled in the Quartus® Prime Pro Edition software version 25.3?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, you may see compilation failure in the design using F-tile Ethernet Hard IP at 25GE-1 variant for non-MAC PCS direct mode with Firecode FEC enabled.
This is because the Firecode FEC isn’t supported in F-tile Ethernet Hard IP at 25GE-1 variant for non-MAC PCS direct mode.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 25.3.1.
Updated 8 months ago
Version 2.0
