Knowledge Base Article
Why do I see clock crossing timing failures for the rx_lanes_aligned signal in the Interlaken (2nd Generation) Intel® FPGA IP design example?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.1 and earlier, the rx_lanes_aligned signal was not synced to usr_clk before exiting to the intellectual property (IP) core. This can cause metastability at the user logic if it is not synchronized by the user. The metastable issue can propagate to the user logic even if the change of aligned is not frequent.
Resolution
To work around this, Intel recommends adding a synchronizer to the rx_lanes_aligned signal onto the usr_clk domain.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
