Knowledge Base Article
Why do I see bit errors with my DDR3 controller?
Description
You may see bit errors with your DDR3 UniPHY memory controller if the REFRESH command period, tRFC, is set too low.
Resolution
The memory controller could perform READ or WRITE commands before the REFRESH cycle has completed causing the corruption of data. Make sure to set the tRFC timing parameter in the Megawizard GUI to the correct value specified in the memory device datasheet.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
