Knowledge Base Article
Why do I see a large number of warnings related to RAM blocks being synthesized away when compiling an Intel® Stratix® 10 FPGA or Intel Agilex® 7 design with the JESD204C Intel® FPGA IP in RX Simplex mode?
Description
When compiling a design with the JESD204C Intel® FPGA IP in RX Simplex mode targeting Intel® Stratix® 10 devices with E-Tile transceivers or Intel Agilex® 7 devices using the Intel® Quartus® Prime Pro Edition Software version 19.2 and later, you may see warnings like the ones shown below.
The following warnings are related to signals rx_eb_data_soemb_out_w_w[L-1:0] and rx_eb_data_somb_out_w_w[L-1:0] and can be safely ignored as only bit [0] of each will be used as an input to the transport layer.
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[129]"
 Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[130]"
The following warnings relate to signals j204c_rx_cmd_data [18:7] when the sync header configuration is CRC-12.
However, these can be safely ignored as the CRC-12 configuration only uses the lower 7 bits (thus, 12 signals will be synthesized away).
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[138]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[139]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[140]"
 Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[141]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[142]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[143]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[144]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[145]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[146]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[147]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[148]"
Warning(14320): Synthesized away node "u_j204c_rx_tx_ss|j204c_rx_tx_ip|intel_jesd204c|intel_jesd204c|j204c_rx_base_inst|j204c_rx_ll_top_inst|rx_ll_per_lane_inst[0].j204c_rx_eb_inst|j204c_eb_fifo|j204c_rx_eb_fifo_noecc_inst|j204c_rx_eb_fifo_noecc|scfifo_component|auto_generated|dpfifo|FIFOram|altera_syncram_impl1|q_b[149]"
Resolution
These warning messages are expected and can be safely ignored.
Updated 11 months ago
Version 3.0
