Knowledge Base Article
Why do I receive incorrect data returned from my read TLP requests on my Intel® Avalon®-Memory Mapped 128 bit Hard IP for PCI* Express?
Description
Due to a problem with the Intel® Quartus® II and Prime software versions 15.0, 16.0, 16.1, 17.0 and 17.1 you may see incorrect read data when the PCI* Express link is highly utilized and there are a lot of out-of-order completions. This problem only occurs for PCI* Express Hard IP Avalon®-Memory Mapped 128 bit variants.
When this happens, parts of data from incoming reads may appear in the middle of data from a previous read.
Resolution
This problem is caused by the memory holding the completion buffer being sized too small.
To workaround this issue follow these steps:
- Look in the generated file directories for the file altpciexpav128_rx.v.
- Find the line localparam CB_RX_CPL_BUFFER_DEPTH =256;
- Change the line to localparam CB_RX_CPL_BUFFER_DEPTH =512;
- Find the lines “wire[7:0] cplram_wraddr;” and “wire [7:0] cplram_rdaddr;”
- Change the wire width from 8-bit to 9-bit:
- wire [8:0] cplram_wraddr;
- wire [8:0] cplram_rdaddr;”
Version Found: 15.0 and 16.0 to 17.1.1
Version Fixed: 15.1 and 18.0
This issue has been fixed starting in software version 18.0.
Updated 2 months ago
