Knowledge Base Article
Why do I get ERROR: SOPC_KIT_NIOS environment variable not set?
Description
Due to a problem in the Quartus® Prime Pro Edition Software 24.2 for Linux, when generating a BSP with NIOS® V, you might see an error related to the SOPC_KIT_NIOS environment variable and thus be unable to generate a BSP.
Resolution
To workaround this problem, add the SOPC_KIT_NIOS2 environment variable as follows:
export SOPC_KIT_NIOS2=1
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 10 months ago
Version 2.0
