Knowledge Base Article
Why do I get a no-fit when using the Altera External Memory Interface IP in an FPGA device that has a relatively low number of IO banks?
Description
When compiling the DDR3, DDR2, LPDDR2, QDRII or RLDRAM II Controller with UniPHY IP using an FPGA device that has relatively low number of IO banks, you may experience a no-fit and possibly the following Quartus® II error.
Error (175020): Illegal constraint of fractional PLL to the region
The problem occurs if all the IO banks on a certain side of the FPGA have been fully used by the memory interface and the PLL input reference clock and other miscellaneous memory interface pins do not have the same IO standard as the memory interface IO.
Resolution
Set the PLL input reference clock and other miscellaneous memory interface pins to have same IO standard as the memory interface IO.
Updated 11 months ago
Version 3.0
