Knowledge Base Article
Why are there errors while generating an example design using GTS Transceiver with Dynamic Reconfiguration (DR) between two rates in the Quartus® Prime Pro Edition software version 25.1?
Description
Performing DR between two rates using the GTS Transceiver was throwing an error when using manual adaptation mode during example design generation.
The errors reported in the IP Catalog GUI during the generation process appear due to the in-built functionality of adaptation mode being set to disabled in the simulation. Due to the disabled adaptation mode, any non-zero values for RX PMA analog parameters in simulation mode throw an error.
Resolution
To work around this problem in the Quartus® Prime Pro Edition software version 25.1, set RX PMA analog parameters in the IP Catalog GUI to 0.
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
