Knowledge Base Article
Why are the R-Tile AXI Multichannel DMA IP Design Example DMA Queues stuck when the Gen5 IP configuration links downgrade to Gen4 or lower speeds?
Description
Due to a problem in the Quartus® Prime Pro software version 25.3.1 and earlier, the AXI Multichannel DMA IP Queues will stick if the Gen5 configuration of the IP is link downgrades to Gen4 or lower. For example in the Gen5 IP is used in a Gen4 system.
Resolution
To fix this problem in Quartus® Prime Pro software version 25.3.1 please install patch 1.01 below.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
IP Core
AXI Multichannel DMA IP for PCI Express*
Updated 5 months ago
Version 5.0No CommentsBe the first to comment
