Knowledge Base Article
Why are the Low Latency 40G/100G Ethernet IP pause timers off by a factor of two?
Description
Due to a problem with the Intel® Low Latency 40G Ethernet IP core, you will see the pause counters increment twice as fast as expected.  You will see this behavior for both Standard Flow Control and Priority Flow Control modes.
Resolution
This problem has been fixed in the Intel Quartus® Prime version 16.0 software.
Updated 1 year ago
Version 2.0
