Knowledge Base Article
Why am I seeing optimized simulation failures for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) enabled designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1, you may see some of the optimized simulations fail, which use Default Simulation Models* for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) enabled designs. This problem happens if the KR CPU is restarted while Auto-Negotiation (AN) is in progress, which would cause AN to fail.
Resolution
It is recommended not to restart the KR CPU while AN is in progress. This problem is not seen for regular simulation or Fast Simulation models.
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
*Note - Refer to Fast simulation model and Default Simulation model KDBs for more details.
Updated 4 months ago
Version 4.0
