Knowledge Base Article
How do I revert from Fast Simulation Models to the Default Simulation Models in Quartus® Prime Pro Edition Software version 25.1.1 onwards?
Description
Follow these steps to revert the "Fast Simulation Models" to "Default Simulation Models" in designs targeting Agilex™ 7 FPGA, Agilex™ 5 FPGA, or Agilex™ 3 FPGA devices in the Quartus® Prime Pro Edition Software version 25.1.1 onwards.
Resolution
  1. Generate the example design from the .ip file or create a custom design for simulation (the same as the current flow).
  2. Update the auto-generated simulation script to point to Default Simulation Models by setting the following variables with either of the following methods:
    • Method 1: For Questasim
      • Update the Tcl-based scripts  (msim_setup.tcl) with the following variables:
        • set DEVICES_SIM_LIB_DIR "$QUARTUS_INSTALL_DIR/../devices/sim_lib/"
        • set QUARTUS_SIM_LIB_DIR "$QUARTUS_INSTALL_DIR/eda/sim_lib/"
    • Method 2: For VCS (2-step), VCS (3-step)
      • Update the qsys-generated script (sh based scripts: vcs_setup.sh or vcsmx_setup.sh) with the following variables:
        • DEVICES_SIM_LIB_DIR="$QUARTUS_INSTALL_DIR/../devices/sim_lib/"
        • QUARTUS_SIM_LIB_DIR="$QUARTUS_INSTALL_DIR/eda/sim_lib/"
The IP example design for these devices has been enabled to use Fast Simulation Models by default in the Quartus® Prime Pro Edition Software version 25.1.1 onwards.
Additional Information
How do I use the Fast Simulation Models to improve the simulation time in the Quartus® Prime Pro Edition Software version 24.3.1 onwards?
Updated 11 months ago
Version 2.0
