Knowledge Base Article
When using the Intel® FPGA P-Tile Avalon streaming IP for PCI* Express with a 125MHz application clock frequency does the timing analyser report 250MHz being used?
Description
Due to a problem in v20.3 the GUI for the Intel® FPGA P-Tile Avalon streaming IP for PCI* Express, the GUI indicates support for 125MHz application clock frequency in Gen3 capable configurations of the IP. 125MHz application clock frequency is not supported, if selected the IP will be generated using a 250MHz application clock, no warnings, errors or informational messages will be seen.
Resolution
No workaround for this problem exists in v20.3 of the Intel® Quartus® Prime Pro Edition of software, as 125MHz is not supported.
These incorrect 125MHz options have been corrected starting from version 20.4 of the Intel® FPGA P-Tile Avalon streaming IP for PCI* Express IP.
Updated 2 months ago
Version 2.0
