Knowledge Base Article
When using the E-tile Hard IP for Ethernet Intel® FPGA IP in 100GE or 1 to 4 10GE/25GE with optional RSFEC and 1588 PTP core variant with PTP enabled, why does the fitter fail if using the EHIP 1/3 IEEE1588/PTP channel placement restriction?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition version 19.1 software,  the E-tile Hard IP for Ethernet Intel® FPGA IP in 100GE or 1 to 4 10GE/25GE with optional RSFEC and 1588 PTP core variant with PTP enabled cannot pass fitter compilation if using EHIP 1/3 as the channel placement restriction.
Resolution
To work around this error, use EHIP 0/2 instead of EHIP 1/3 as the channel placement restriction.
This problem has been fixed starting in v19.2 of the Intel® Quartus® Prime Pro Edition software.
Updated 2 months ago
Version 2.0
