Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 25.1.1?
Description
The latest device firmware for the Quartus® Prime Pro Edition Software version 25.1.1 can be downloaded from the following links.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 1.33fw:
Fixed race condition in handling SHA isr and resumption of FPGA data blocks.Drain DMA post a configuration/PR to flush out left over data if any.
Firmware version 1.22fw:
Enabled 85 Ohm Rx Termination for PCIe designs.
Resolved problem related to Ethernet Auto-Negotiation and Link Training (AN/LT) designs on F-Tile FGT having link up issue
Resolved problem related to IEEE 802.3-2022 50GBASE-KR compliance testing marginality during Link Training (LT).
Resolved problem related to FGT transceivers using certain FGT Attribute Access method sequence hanging.
Firmware version 1.15fw:
Added Safe SEU error injection mailbox command.
Please also see the following links:
Resolution
Download the latest device firmware below.
Note:
  • Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
  • Recompilation is not required.
  • All programming files should be recreated.
    • Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
Updated 5 months ago
Version 2.0
