Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.2?
Description
The latest device firmware for Quartus® Prime Pro Edition Software version 24.2 is available for download below.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.04fw:
This patch fixes the issue of incorrect data retrieval in the GET_I2C_TELEMETRY command.
Firmware version 0.10fw:
This patch fixes to reissue PLL lock request to achieve true independent PERST.
Firmware version 0.54fw:
This patch fixes issue where the HPS will get stuck at FSBL on certain units above Quartus 22.2B94 / or with firmware above 22.4B94.
Firmware version 0.59fw:
This patch includes fix to improves voltage sensor reading stability.
Please also see the following links:
- Updating the SDM Firmware in the Agilex® 7 FPGA Configuration User Guide
- Updating the SDM Firmware in the Stratix® 10 FPGA Configuration User Guide
Resolution
Download the latest device firmware below.
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run programming file generation or conversion using the Quartus® Prime Software programming file generator.
